- Thread starter
- #11
Harmful to what? The environment? Counters? Windows? I'm guessing you didn't mean printer heads/nozzles.Windex was more harmful than you think, why do you reckon they removed the ammonia..
That’s exactly what I meant..I'm guessing you didn't mean printer heads/nozzles.
I whole heartily agree, but you have to look at the big picture, as they have done, it must have been affecting a lot of other things too other than metal.. why else remove it. !I'm fairly sure Windex's parent co. doesn't give a rat's posterior about anyone's print heads.
I use W5 window cleaner with great success, but back in the days of Yello Gello, pharmacist solution was called for..
You see, you got there in the end…that they had to cancel it because it was allegedly bad for the environment.
Really? An "I told you so" ? It's also not true. You said it was because it damaged printheads. I said it was because they told me it damaged the environment.You see, you got there in the end…![]()
