- Dec 27, 2014
- Germany
It's how the paper surface is reflecting the measuring light coming from the spectrophotometer, and the vast majority of papers can be tested with the standardized 0/45 deg light path in the photometer before the light hits the sensor. But as mentioned a few - a very few papers come with a coating which let the light being dispersed wider than on most other papers.Is this problematic reflected light coming from the devise or is it ambient light?
Here are some links explaining the working of a photometer and the light path, it is mentioned somewhere that the 'normal' spectrometer is to be used on matte - smooth surfaces which excludes highgloss structured surfaces
https://www.xrite.com/blog/what-is-a-spectrophotometer
It was the above gamut plot at the lower luminance, the ondulated line of the gamut which made me remember that I had seen a very similar plot long time ago. Again - yes - the explained effect can cause some weird looking gamut plots but as a rare instance . Try the above mentioned actions - rescanning and as well using a smaller patch count
