- Dec 27, 2014
- Germany
I take the little table from above and add the deltaE readings just for the middle gray spot on the target sheet
HP Premium Plus
Photo Paper__________7.67________5.86
Canon PT101________10.26________7.60
Sihl 0769____________10,33________8.80
Emblem 240g_______10.44________8.71
Glossy 240__________10.45________8.39
That's the numbers in the right column you get with the very much simplified method just to read the luminance/color shifts of a single gray patch, since it is a gray patch for which all averaging of colors is done upfront by printing gray, and you should get numbers with the same relation to each other by reading the changes via the histogram display, it's just on a different scale. This method may not be as accurate as using expensive hardware/software but it's free and rather quickly can show you step function performance differences between inks and/or papers.
HP Premium Plus
