Chroma Optimizer got slight magenta color cast
Pipur
Stockholm
Canon Pixma Pro-1
Chroma Optimizer suddenly shows a slight magenta color cast on the nozzle check after replacing cartridge (both original).
It had been sitting unpowered for a while.
Anyone with any ideas? (Canon Pro-1)
Hard to say because the Pro-1 is a very special printer. Forum member and moderator @The Hat is our Pro-1 expert. Maybe he'll be able to help you.
On my Pro10s once I had a strong cyan cast on nozzle checks in the chroma optimizer, but it was because I refilled by mistake the CO cart wih photo cyan ink. :rolleyes:
Flageborg
Epson R3000
... a slight magenta color cast on the nozzle check after replacing cartridge (both original)...
Yes, in a split second you found that you were about to insert the Magenta in the CO bay and transferred a small amount of Magenta to the CO input pin.....you removed it fast, but not fast enough
Pipur
Stockholm
Canon Pixma Pro-1
Yeah, that might have been a plausable explanation.
But, unfortunately - no; has to be some other reason.
Thanks for the suggestion though!
Pipur
Stockholm
Canon Pixma Pro-1
Wow, what a bummer...! :oops:
What cartridge were you replacing?
You already said you use OEM cartridges. Do you refill or use only new OEM cartridges to replace empties?
Do you notice any leaked ink on or around the print head?
Any other issues or changes with the printer or printed output?
Please print, scan, crop and post your nozzle check.
Just run a clean cycle before your next print, it maybe a 1 off.. Check and see if the cart is seated properly..
The Pro 1 won’t allow that to happen with OEM carts..
Flageborg
Epson R3000
Pipur
Stockholm
Canon Pixma Pro-1
As in subject: CO.
Only new (at least unopened) OEM.
Nope.
I decided to print a whole sheet covered with CO, and a nozzle check after that.
And just like that it's gone. For now...
Big thanks for your engagement! :thumbsup
