- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
You are probably right. The MP550 and MP560 might be identical or very similar. I searched for a service manual and parts catalog for the MP550 and found this. It is a service manual and parts catalog for MP560 in one PDF file. But notice the file name that suggests that the manuals also apply to the MP550.QC3-3927 seems to works also on MP550...
I think that the ink stain on the right hand disk can cause the error 6000 as the sensor could skip some markings. This could bring the optical readings for the two disks out of sync. If rubbing the disk with pharmacist's cleaning solution on a piece of soft tissue paper doesn't work then try to add some extra ammonia to the solution or try a window cleaner with ammonia.By the way, I found some stain on the wheel (see picture) but I can't get it away with the "Pharmacist Solution".
What do you think about?
You might consider a new printer instead of spending 45 Euros and not being sure if it will work.
I agree.
If no change, then new printer time.
