- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Correlation does not imply causation. More information not yet revealed required. None know the batch identification or the particulars of each refilling behavior or condition of the cartridges.
Again, how does the overspray/whatever of Magenta in Palombian's nozzle check relate to the ink starvation appearance he also suffers from? These seem to be distinct issues.
This magenta issue remembers me of comparable observations with the 9500 magenta (IS formula 6162).
I replaced this with Prodinks magenta (with the MBK the only ones who had no clogging
It was mostly a banding pattern, do not remember nozzle pattern issues.
But it was cartridge related, I sorted them out bad or good.
Will rinse a PGI-72M cart and refill again with Octoinkjet magenta. You never know.
As already suggested alternating with OEM could keep the nozzles clean.
Since @mikling warned about using PRO-9500 inks in the PRO-10, I will not go this way at the moment.
PS: I try not to read too much in nozzle checks.
