New Prusa 2 Slicer
f you want to try out the new Prusa Ver 2.0 Slicer this is a good walkthrough on setting it up...
I do not have a 3D printer but I enjoyed this well done video. Dave makes the complicated seem easy.
Brother MFC-L8690-CDW
Yes, there are so many settings and parameters in slicing programems and all of them can have different names for the same setting, so a simple to understand walkthrough makes all the difference.
Dave needs to see from my side…then he might think different..:eek:
Just changing one setting can Frig the whole thing up..:he
I became a bit sceptical when I saw him coping the CURA Start/End Codes… :confused:
What are you skeptical about? :idunno
The main reason for my scepticism was Prusa 2 Slicer are well capable of producing their own codes or even using CURA settings, but expecting users to plagiarize them is a bit rich.. :eek:
I looked up Cura. It is an open source free app. So, no stealing or plagiarizing in this instance. But I hear you about Prusa being able to generate their own codes. Since I don't know these software I cannot speak to much about any of it.
NurseBob
FWIW, end and start codes, regardless of manufacturer, are G-Codes, which is the standard means of "talking" to a 3D printer, and originally for CNC machines. They are a standardized set of instructions.
Edit: When you run slicer and export, the resulting file is all g-code. If you want, it's a text file and can be opened with any editor. Slic3r walks through your model in the same manner that a CT scanner does and creates layers for every millimeter in elevation that describe the set of movements to the print head in 2D space. Each layer is the Z-axis, which is the 3D component.
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
I'm actually surprised there are so many different slicers out there. I guess that's good since competition is always good for the consumer (me) :D
Cura might not be the "best", but it does everything I need, I'm used to it, and there are a MILLION tutorials, videos, help discussions, etc. for it, so I stick with it.
