- Apr 19, 2007
- USA
- Canon MB5120, Pencil
https://kb.sandisk.com/app/answers/...fference-between-sata-i,-sata-ii-and-sata-iiiSATA-3/600 SSD
SATA III = Faster Data Transfer Rate = Good
The brand of SSD you get is up to you. There is more than one that perform well, but, yes, I think Samsung Evo's are a safe bet in general.Thanks once I get this computer on line it will need a video card and a Samsung SSD.
Your Dell Optiplex 7010 with I5-3570 3.4G processor should have a graphics chip built in. From my research it may be the Intel® HD Graphics 2500. (Supported games per Intel) This will be sufficient for much or all of what most people do except for certain games played at high resolution / special effects levels and intense photo/video manipulations. Simple image/video manipulations probably will be fine with this GPU (Graphics Processing Unit). If not then you can add a video card and simply turn off the onboard graphics chip in the BIOS/EUFI.
If I am looking at the right computer, yours has both a Display Port and a VGA port on the back to plug in two monitors at one time. Nice.
Also, you might be happy with the 2 TB HDD that comes with the computer. Give it a good test drive before buying an SSD. You can always spend money later.
