STILL TRYING
phild
Brother mfc j6930dw
Hello again
Im on a ciss system with a Brother MFC j6930DW printer. Everytime I do a print check everything is okay with the chart ( missing blanks etc ) but I still have white lines going horizontally across the page. Ive cleaned the scanner glass, opened up the main unit and cleaned the rollers, Ive done numerous print head cleans but still the white lines. Any ideas ??? Thanks. Phil
Where exactly is the problem, is it your printer or your scanner or both..?
What you could try on your printer first is to raise the top lid up 5cm during printing and that should stop the tubing bouncing off the lid during its travels.
Tip: a Ciss is not very good on any printer that’s not maintained on a daily basis, it need constant upkeep to stay relatively stable..;)
phild
Brother mfc j6930dw
Hi
It produces horizontal lines on copying and when
I
Hi
It produces horizontal lines when I copy and when
I print from my pc/ The printouts I get from checking the quality is always great but still the lines.
Many thanks
phild
Brother mfc j6930dw
So are you saying it’s your Scanner that has the issue. ? :hu
Everything. Im beginning to think I may need a new printhead. I dont understand how the printout quality report sheet is great but as soon as I print anything it has the horizontal lines.
