- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
I have had a similar problem with a CLI-521 M cartridge. It would not deliver ink, whether it was top filled or refilled using the German method. You couldn't even make it drip ink when blowing hard into the vent. Flushing and cleaning the cartridge and treating it with pharmacist's conditioning solution made no difference. Even with the refill hole left open after a top fill the ink would not enter the sponges, it stayed in the ink chamber.
I cut open the cartridge to investigate, I found a little needle damage caused by the German refill, but that was not the cause of the problem. I tried to dip the sponges in a little ink in a shallow tray, and to my surprise the bottom sponge that is supposed to be very hydrophilic would not absorb the ink, it had somehow become hydrophobic. The fibres in the sponges are polypropylene, I think. I found out by a simple burn test. Normally polypropylene is hydrophobic, so some treatment of the sponge material must be used. Maybe several refills and purges washed away a chemical treatment of the sponge material?
This was a year or two ago. I never found the cause of the problem, and I have luckily not experienced it since.
