- Thread starter
- #21
Robert the Bruce
ok, here are the shots I took when disassembling the print head.
The one of the bottom of the head was taken before wiping off - lots of cleaning cycles had produced rather a mess here!
I have inserted the images as thumbnails here. If anyone wants more detailed ones I can attach them to another message.
You should be able to see the two screws that have to be removed to take off the nozzle plate. This is then only attached with the brownish (mylar?) ribbon cable. It seems to be fairly robust, but obviously if you damage it by letting the nozzle plate flap around you've wasted your time!
I haven't shown the elastomer gasket in place, but it goes between the little protrusions on the underside of the plastic part of the head and the holes in the top of the nozzle plate. The latter seems to be ceramic on top, with a metal plate bonded to it underneath in which the nozzles are actually located.
You'll notice that, in addition to the slot for the PGBK, there are six little holes in the ceramic, corresponding to the rows of colour nozzles - two magenta, two cyan, one yellow and one photo black. There are *seven* protrusions and corresponding holes in the gasket. I have no idea what the 7th one is for, as it doesn't seem to match up with anything on the ceramic block. Perhaps this is intended for a higher end model with a six-colour ink system?
