Canon Pixma MG5150 color print quality decline
Łukasz
Poland
MG6250 (MG5150 before)
Martin is right, x20/x21 ink type printers have third bar for C and M inks. And they have only one "blue block" lower?
x25/x26 ink type printers have only two bars in extended nozzle check, but they have second "blue block", i guess for testing small droplets only.
And here are four test prints:
iP3600 MG5100
iP4800 MG6200
Peter is also right with yellow/green bar.
Third bar may be sometimes very hard to spot (not picked up in scanned image), but in MG5100 (MG5150) test print there is no room for third bar...
Ł.
Except for price of OEM Magenta ink tank - yes.
Except we are trying to diagnose the problem, not avoid cost at the price of success. Since the OP is refilling OEM Canon cartridges with aftermarket ink unknown to the forum, I was going to recommend trying a new OEM Canon Magenta, or a known working Magenta other than what the OP is already using, but you all seemed to be getting along fine. However, sometimes the direct approach is appropriate even if it entails cost.
iP3600 MG5100
iP4800 MG6200
Excellent info for comparison. Interesting how the colors vary between the prints. What manufacturer of inksets are used?
martin0reg
Germany Ruhrgebiet
iP3600 MG5100
iP4800 MG6200
Ł.
Thank you for posting, very helpful for users of these (and other) canon printers!
Łukasz
Poland
Some notes on scanned images:
- Full plate/A4, 150 dpi
- all auto options/correction set to "off"/"disabled"
- "Image Adjustment" set to "None"
- Descreen option set to "on" in order to avoid rainbow-like Moire artifacts on grids/screens
- CIS scanner from MG6250, stack of paper used instead of crappy pressure sheet
SMode Test Print from iP3600
- from 2-nd hand, seller claimed clogged printhead
- unknown compatible inks
- clearly visible too high viscosity (see "blue block" artifacts, no second "blue block" at all)
SMode Test Print from MG5100 (MG5150)
- my first detachable carts Pixma
- compatible inks branded "PrintLab" (very popular in Poland)
- print was done shortly after replacing setup OEM's carts (never refilled, nor even completely exhausted)
SMode Test Print from iP4800 (iP4850)
- from 2-nd hand, seller claimed clogged printhead, after flushing
- distortion on dye BK
- some clogged nozzles on 1/2pl Cyan
SMode Test Print from MG6200 (MG6250)
- printed on thicker media, cardboard like drawing paper(?)
- distortion on dye BK, Yellow
Ł.
I just made a test with a Canon iP4000 to verify that a too weak magenta would cause a green cast to the rectangles and lettering in the nozzle check printout. I first made a nozzle check with the normal inks, and then a nozzle check with the regular magenta replaced by photo magenta. Here is the normal ink, the small rectangles and the lettering are nearly neutral grey:
Here the regular magenta is replaced with photo magenta, the rectangles and lettering are now green and the light magenta barely visible in the scan:
martin0reg
Germany Ruhrgebiet
I just made a test with a Canon iP4000 to verify that a too weak magenta would cause a green cast to the rectangles and lettering in the nozzle check printout...
Clever test indeed, thank you Peter!
BTW color cast in the bars and letters on the left I had (and still have) frequently with my canon's ... but each time it was caused by clogged or burnt fine nozzles (for the light colors) or by ink starvation ... I don't have any photo/light ink for canon to confuse...
Aleksandar84
Canon Pixma MG5150
This post of yours was super useful!!! So I came across a epson refill ink bottle magemta, model T6643...can I use this ink for my canon or it will damage the nozzles due to different formulatiom, viscosity etc etc? Its genuone epson ink and is three times the price of the inks I use now.
Łukasz
Poland
In a very short way:
Piezo ink can't be used in Canon/HP/Lexmark/Dell and other thermal inkjet printers.
Ł.
