Black marks on prints - SC P800
johnrobinson
Print Lurker
Epson Sure color P800
Hi, I have a SC P800 and started getting black marks at both ends of my prints. I don't get these when I do a nozzle check print.
Any advice would be grateful.
All the best
John R
could you upload a picture to better determine what the problem is ?
johnrobinson
Print Lurker
Hi, These two images showing the scuff marks, they look like roller marks, but the paper gets fed into the printer in portrait mode but the marks are running down the side of a landscape mode.
Any suggestions?
All the best
John - London
I find the strange banding very strange provided the paper is fed in portrait mode. It look like there are some stains on the timing strip causing this behaviour.
L805, WF2010, ET8550
You are most likely using some other type of paper for a nozzle check.
How much do you/did you print with this model - the nozzle check should tell you. It could be that the printer needs some internal cleaning - the timing strip - the lip which wipes off the nozzle plate which is part of the cleaning unit, is there any pigment smudge build up - and it could be as well the paper which is curling, You can bend the paper edges the opposite direction, and use a similar type of paper from another supplier.
