- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
If any of you guys are contemplating the use of GO for testing in your cartridges, this message is just for you.
The best Gloss Optimiser for the job is I.S. GO for two reasons,
one it give good coverage over all your lovely photo prints and two which is the most important here,
it doesnt harm your print head.
I used OEM Gloss Otimiser for one of my tests in my cartridges; it turned out it was totally useless altogether for the job,
because it burned out my print head in a matter of minutes,
and my advice to you is just DONT USE THE STUFF.
Whatever way this OEM GO is made or its Viscosity it wont flow out of a cartridge at all
with the result it starves the print head of vital moisture which results in permanent nozzle damage.
I am not promoting the use of I.S. GO here in this thread but I suppose I should be,
but what I am strongly suggesting is not to make the same mistake I made
by using Canon GO and buggering up a perfectly good working print head.
Foot Note I never had any problems whatsoever while use I.S. GO in any of my printers before..
