Please help:
Seeking a secondhand working or not working Canon i865 / i860 / mp750 / mp 770 / mp760 /mp 780 / mp 790 / ip4000 / ip4100 / ip4000r / ip 4100r printers, for ecological reuse/recycle reasons only. (I happen to have a good printhead and an assumed damaged mainboard and don't want to throw the printer away - if I can make one good one out of two bad ones I would be very happy, or if someone else can use it I would also be very happy)
anatomy of situation: printer mechanically works fine, has had moderate use during it's long life. Have a problem where printouts - including test ones - have consistent banding at about 50% coverage.
I was using it for black only on draft. I wanted to print CD's in colour and print a few photos of the son.
It had blocked colour heads, so washed the printhead to try clear them, but didn't wait long enough for it to dry. Put the printhead back in the printer, and then no black either - just a bit of print with banding on all colours. Traced new fault to 2-3 burned tracks on the ribbon between the bj printhead and the copper interconnector PCB at the back of the printhead. Could solder them, but I would need a needle-sized iron and wire, and really don't feel like spending hours on a microscopic solder job. So I bought a new printhead. Only issue is that the new printhead does the same as the old one - so when I put the old still-wet printhead into the printer, and the tracks fused, it must have also burned something out in one of the IC's on the motherboard.
So I can send anyone interested the printer, cd bits and two printheads, OR if someone has a compatible unit, I would consider buying it if the price is right.
Cheers,
Cheers,
