Vertical lines on test strip
bsegel
Hi,
can someone tell me what is causing the vertical lines you see on my test strip? I've tried cleaning the head several times, nothing seems to help.
Canon iP6700D
Thank you
I think this is more of a electrical problem rather then a clogging: as the ink sprayed from left to right this is not typical of a clogging problem. Your black looks very weird indeed. Did you try cleaning the gold contacts both on the printhead and the craddle where it sitting in ? You can use a pencil rubber to clean it.
lin
bsegel, This is cause by the timing strip. Wipe your timing strip with a soft tissue to wipe away any grease stains that might have accidentally gotten onto the timing strip.
