Using 103 Ink in Epson L1300?
aspe0308
Epson L1300
Hello,
I have an Epson L1300 and my ink is running low, so I considered using 103 ink from my Epson L1110 for it. Would this cause me any problems?
I was reading other threads here and some people say that dye-based inks should be fine, but I just wanted to double check.
Thank you very much!
Yes, that printhead runs it all - dye and pigment, this printhead is produced since a long time and is used in lots of
lower end expression home - dye - and workforce - pigment - models
aspe0308
Epson L1300
Thank you. Mixing different types of dye inks (664 & 103 in this case) is completely fine? Could I just refill it normally or it requires another procedure?
