AmaDeuSbg
- Aug 15, 2023
- EPSONS: L1300, L805,L850,L1800
Hello guys,
It is me again. I just received the 106 CMYK and LC LM T54C inks and I plan to put them in my Epson L1800 which is currently using the 673 inks.
I was wondering what will be the most "professional" way to do it? I was thinking just to suck out the inks from the tanks and the inks from the tubes through the dampers and then pour some of the 106 and T54C inks (like 10ml each color), then suck that out too and pour again (hoping that this will mix the leftovers of the 673 inks) and then pour again fresh 106 and T54C inks. I was wondering if this is OK or if it will be recommended to use any cleaning or other solution prior swapping one ink to another?
I have some sublimation cleaning liquid but I am not sure if it is a good idea using it and decided to better ask.
Thank you and have a lovely day!
