Suggest an Ink Saver Software?
Prashob131
I tried Inksaver 2.0 unfortunately its not working in my windows 7 (32-bit) with HP 4288 printer, Is there any other similar genuine software?:|
qwertydude
I don't know about you but I don't know why you'd institute a program that will wash out color. If refill ink is too expensive then you can always find a cheaper ink. The whole purpose of refilling printers, and why this forum exists, is to print as much as you want with no fear of using ink because in reality ink is a pretty cheap commodity.
Grandad35
North of Boston, USA
Canon i9900 (plus 5 spares)
What does this software do that lowering the "Intensity" setting in the printer driver doesn't?
Prashob131
Ok, problem solved somehow, now its working flawlessly.
Now i need a "Printer Page counter" software, which will show total no of pages printed, Please suggest some....
Yea, but unfortunately the hp cartridge with my printer uses a chip which is causes problems after refill, like not showing actual ink level,head it sometimes just refuses the refilled cartridge after it has taken out 3~4 times from printer(printer detects it), this cartridge has only 4ml capacity, so one has to refill often but after refilling 3~4 times it just shows "cartridge problem". Do anyone know how to reset ink level in cartridge hp60?
This program gives good control (percentage wise) over the ink used on paper.
qwertydude
You can refill hp cartridges numerous times, more than 3-4, the trick is you can't let them run out. If they run out it's very difficult to get them to print again or they burn out their print heads.
sllowmail
If you're refilling your ink cartridges, dont you think it's silly to save ink?
Prashob131
No, by using inksaver software i dont need to refill the cartridge often(low volume 4ml cartridge like hp60).
Not only it saves ink, there is increase in print quality and lower sound frm printer.
Latest posts
