Repairing Laser printer Fuser Pressure Roller with PTFE heat shrink?
Smile
Europe EU
Hello,
Some printers are still working but Fuser parts like the Pressure Roller is not available or easy to get.
I had an idea that the Pressure Roller could be repaired using PTFE heat shrink.
There are many variations available, transparent and color. Semi rigid and soft.
Aliexpress is the only option else it costs too much
1m PTFE Plastic Heat Shrink Tube Diameter 16mm ~ 40mm 200Deg.C 1.3:1 Shrinkage Ratio High Temperature 600V Translucent FEP F46
https://vi.aliexpress.com/item/1005007771672339.html
Any idea if this would actually work?
