Red Banding on Pixma MP810
mobilelawyer
I am debating on wether to order a new print head, or a new printer.
I get uniformly- spaced red banding on all prints. It looks like jail bars:
(sorry. had to delete the link to the photo, new member) The jail bar description should tell you what I see.
If I run a nozzle check, I get this result:
(sorry. had to delete the link to the photo, new member) The first magenta bar has a much- darker lower half. No issues seen in the others.
I have several deep cleanings to no avail. The problem replicates itself every time. I have also let the printhead soak in windex. Same result.
All of my cartridges, including the magenta are fresh: the banding existed with the old magenta cartridge, too.
If the banding was white, I would be ordering a new printhead. Not sure about this, though.
Advice, please and thanks in advance.
There is a 24 hour quarantine period before new members can post links. But from your description it looks like the printhead has developed an electric fault. If that is the case, only a new printhead will help. Clogged nozzles show a more random distribution, a regular pattern means an electric fault.
Does your nozzle check look like this, but with the problem in magenta instead of cyan? http://www.nifty-stuff.com/forum/viewtopic.php?id=6747 . In that case the problem was solved by installing a new printhead.
mobilelawyer
Many thanks for the reply. Yes, the cyan strip on the link you sent looks exactly like the magenta strip from the nozzle check print out on my printer.
Now I have to consider the cost of a new print head vs. replacing the printer, as well as the risk that replacing the print head does not solve the issue!
But I just bought about eighty dollars worth of consumables for the MP810, and that fact alone would mitigate in favor of a new printhead if that is the problem.
Many thanks for your kind and quick reply.
