First Post
I can not resist a bargain so when I had some issues with my R800 which I have used for almost 7 yrs I considered upgrading my printer and so I saw a link to a brand new never used R1800 in the Netherlands SO ON ebay I got it for $19.75 AU with $ 140 POSTAGE
so I ran with it.
I bought a CIS for it a RIHAC which have a good reputation so I read every post re: blocked heads etc and prepared to clean the printer and get it going, well 3 weeks later 1.5 sets of OEM inks +1 set of inks the damn thing would not print.
Windex and gentle pressure ensured that the head was cleaned, I even got real good at removing the case etc. I concluded that the FFC cables to the head are not connecting so i bought a set and changed the lead into the head but no it will not print
I even considered following a epson owner who ran over his blocked printer with a 4WD.
I even tried the r800 head in the r1800 and it printed a nozzle test x2 then nothing, ( i am now assuming the ink that was in the head was eneogh to print the nozzle test but no more?
I am now running the CIS on the r800 with no problems ( dare I say so far) so it must be a electrical issue
I have downloaded a wshop PDF and it states that the head if replaced must be entered in the bios ( which is way out of my expertise)
I any one has any suggestions as to why the head does not print as I had the head ultrasonicly cleaned and checked out as ok, I am assuming it is one of the boards or FCC cables
I have read almost every post regarding the r1800 on this forum and know that there are some experienced operaters on the forum
thanks in advance
Bazz8
so I ran with it.
thanks in advance
Bazz8
