problem with bubbles in tubes..CISS
xray34
Hi all,
Epson RX585 with CISS working fine for 18mths, 3 ink topups and 1 complete ink change..
suddenly I have statrted to see small bubbles appear and I.m cleaning heads more often.
Especially if the printer is not used for a day or so these bubbles start to appear..
ONLY in the Light Magenta line..
Can anyone suggest a fix for this?
They only appear near the cart junction and nowhere else..!
Also I have checked all filters and lines and thre appears to be no leaks or anything.
Please See attached image..
xray34 I looked at the image you posted and indeed there are air bubbles in the light magenta tube but if you look again you will see that the yellow also has bubbles. That tends to happen all right when youre not printing for a while. I think its the nature of the beast (CISS) it likes to be kept busy. As you said there appears to be no leaks so no worries, the next time you print some sheets have a quick look to see if the bubbles clear at that spot.
xray34
And indeed you are correct 'TheHat' ..
I hadne noticed the yellow. !! eagle eyes !! hehe
They do clear instantly and I only actually get maybe 1 or 2 pages where there are problems.
Thanks for the fast reply mate..
It seems I will just have to print more..lol
Cheers :)
tsiya
St. Augustine, Florida
As long as the cartridges are holding the ink level the bubbles are nothing to worry about. Some of the ink in the lines drips into the cartridge and air goes in to replace it.
Latest posts
