Printer off-line problem
cybermac228
Escondido, CA
HP OfficeJet 3830
I purchased a new iMac 24 to utilize OS 15 and a new Brother printer MFC-J1205W. Since installing the necessary printer software from the Brother web site, the printer shows as off-line in System Preferences. Any suggestions on how to correct this issue?
x64
Epson Stylus R2400 2100 & more
The steps I would take in your situation:
1. Remove all installed printer drivers and software from computer & factory reset/initialize the new printer.
2. Use a known good printer cable, without using a hub. Disconnect all other USB devices besides the keyboard and mouse.
3. Follow the installation instructions provided by Brother carefully and install the printer.
4. Check if both the printer & computer are up to date (they should be compatible)
5. Use your warranty, something might be defective.
Good luck
cybermac228
Escondido, CA
HP OfficeJet 3830
Good luck
Already reinstalled recommended software from brother website and reset printer. According to Apple, printer cable not required for connection, AirPrint is utilized by first connecting via wi-fi and then removing usb cable. Trying this method using Brother wi-Fi Wizard setup, although printer is compatible with AirPrint, printer not found in wi-fi search. Still on easter egg hunt, back to Brother support.
Redbrickman
Brother MFC-L8690-CDW
Might be a chance that the wifi is faulty on your printer, but more likely your router can't see it. Have you tried moving the printer closer to the wifi router just to get the initial connection and if it works then you will probably be able to move it back to your original place and it will work there.
