hey guys i was having problems with no black printing (small black cart) what i did was remove the ceramic print head part and use some tubing to inject into the each screen everything was fine except for the one that holds the small black cart nothing would flow thru it even after soaking over night the screen apeared to be clean (it was nice and shinny like the others)so i let it soak some more but no change needles to say the ink that im useing must be junk(althought the other colors im not having problems with,why is that)so since the head was bad i remove the screen from that port and low and behold i was able to get it to flow nicely like the others ports so that ink must have sealed up the screen like concrete what do you guys use to get the screens clean i have a feeling that was the whole problem and that i had created other problems by doing other methods that probably wasnt needed(costly mistake on my stupid part)
