GauffDeLieche
- Sep 17, 2014
- Location
- Hannut, Belgium
- Epson 1500w
Hi,
I finally run out of OEM ink provided with the printer.
Time to start a new journey: using the Powerchrome K3 ink from Octoink.
I ordered 250 ml of each color what should correspond to my entire printer life...
1) Ink:
I started first by a newbie mistake: I did not removed the vent plugs from my refillable cartridges. Cause: a big "DO NOT REMOVE" tag just next to them...
But it works much better without
With the plugs no ink any more arrived on the paper surface.
I had to perform several head cleaning cycles and let the printer rest a night in order to have the ink coming again from all the nozzles.
Since I've been using this ink I noticed 3 issues:
Do you have an idea of what's going wrong or what I could test?
2) Profiling:
I've made a first profiling test using my Datacolor Spyder3Print using a 729 colors patch and at first sight everything seems good except the black and white scale:
if you look a the picture (my old scanner is not profiled, colors are poor): Pure black is OK but the 2nd and 3rd patches are really brownish. All the other grey patches are OK. Does anyone has an idea why?
I'll perform a second measurement in order to average the results.
1) Ink:
- Sometimes I see some very small white areas in plain blacks. I suppose they correspond to one point definition that did not receive ink.
Why? Air bubbles?
- I see patterns in plain blues.
(I zoomed on such pattern on the image below)
Could it be due to a bad alignment?
- I have regularly a large drop of magenta ink on the sheets.
See image bottom right.
Would this cartridge have a leak?
2) Profiling:
