P800 Refill options
Where are you located - the situation is apparently different in Europe vs. North America in regards to firmware
restrictions, there are refill cartridges with ARC chips offered in Germany. These won't work in other regions where Epson is tracking unique serial numbers on the chips to prevent re-use of cartridges with the same serial number.
There are adapter boards offered which have a range of valid numbers stored. It is apparently possible that the same
serial number can be used on different printers.
DANIEL TORRES
CANON PRO-100
I'm in the US, with the current firmware the printer does not recognize 3rd party carts, same with the decoder board.
I'm curious about the website linked, if anyone has tried that option.
thanks
There are 2 approaches currently offered - the firmware hack to make the printer virtually 'chipless', not reading any chip data at all, and the use of a decoder board which emulates the chip functions and uses different serial numbers after every reset.
Several companies are offering something like these cartridges
https://www.inkowl.com/wide-format/...cartridge-set-for-epson-surecolor-p800/P8443/ used via a decoder board as mentioned, all that seems to come from China.
I tried to make a P400 chipless, not a P800, it did not work, wrong firmware claimed and other user errors, so I didn't get it working up to now. There are 2 different methods offered for different firmware versions of a P400, and it seems
that a firmware downgrade may not work for all hardware versions of the processor board, Epson may try to counteract against this firmware hack.
DANIEL TORRES
CANON PRO-100
Where you able to restore your P400 to working order with OEM's after the chipless firmware failure?
