Gooneybird
The Canon i950 is about 5 years old, and the original print head lasted about 3 years. The replacement is now acting very contrary, like it's not getting sufficient ink flow after the first or second full page photo print. I've done various types of cleaning, after reading many, many posts on this forum, yet the problem persists. My feeling has now reached the point that it might be related to the "sump pump" or whatever the correct name is. Not too long after installing the second new print head (almost 2 years ago) it started flashing the code saying the pump was full. I no longer remember the exact code, but someone on here (as I recall) had posted the trick on how to reset it, and I did. And it returned to working, until recently when it still tries to print but as stated above, after 1 or 2 sheets it begins failing - lots of banding, incomplete colors or both.
So, without a service manual, I need advice 1) on how to remove the cover so I can access the so called "sump pump" and 2) clear it out or replace the sponge or whatever. If anyone has a service manual in .pdf file format, I would greatly appreciate a copy to study.
This being my first post here, I don't know all the tricks, especially for posting photographs. My reason to bring this up is - I've taken many shots of the first print head that I took out and dismantled, in case anyone would like to see how it's put together. Also I've got an attachment to fit on the end of a syringe that fits well over the individual ink filters for cleaning, and can post a picture of that if wanted.
For a more complete background, I buy a complete set of all 6 Canon BCI-6 ink cartridges and refill them with MIS inks for approximately 10 refills each, then start with a new set. I just ordered a new set of original Canon cartridges and would like to get this sump pump problem (any other identifiable problem) resolved before starting using them.
Thanks in advance,
Olin McDaniel
Thanks in advance,
Olin McDaniel
