joseph1949
To: all
Problem: I ran a nozzle test and it showed no yellow.
Here are my specs:
1. Two-PIXMA MX870 printers printer #1 and printer #2.
2. Each printer uses four-CLI-221 (C,M,Y,BK) carts and one-PGI-220BK cart. All five carts have transparent ink reservoirs.
3. Use InkTec inks. I buy my ink by the liter.
3. I use the top fill method to fill the carts.
4. I use hot glue as the plug material. I use my coin/paper disc method to create the hot glue plug.
See below for pictures of nozzle tests.
On Thursday (10/05/12) I filled a CLI-221M cart for my printer #2. The next morning I ran a nozzle test to see how my filled CLI-221M cart was working. The nozzle test showed that the M cart was fine but there was no yellow. I removed the printhead to inspect its exterior and found no visible problems. I inspected the contacts that surround (but not on the printhead) the printhead. Again, I saw no visible problems. I saw no signs of leaks either inside the printer or leaks from the carts.
I replaced the Y cart from printer #2 with the Y cart from printer #1. I then proceeded to run another nozzle test on printer #2. The test showed no yellow. I then placed the yellow cart from printer #2 into printer #1. I then ran a nozzle test on printer #1. The nozzle test for printer #1 did show yellow.
Conclusion: The yellow ink inlet for the printhead in printer #2 is clogged. The yellow cart for printer #2 is O.K (maybe).
What to do: I assume I need to unclog the yellow ink inlet.
Question: What is the best way to unclog the inlet?
I have read the following reply from Trigger 37:
www.nifty-stuff.com/forum/viewtopic.php?id=63&p=13
see reply #129 (Inkjet Printhead Cleaning Method)
Triggers methods to unclog a printheadthe short version:
1. BASIC CLOG: Rinse the head over and over in medium hot water.
2. Difficult Clog: Repeat everything in step #1 but soak the head overnight in windex and then repeat all of #1 in the morning. If it is not perfect go to #3.
3. Bad Clog: Build a set of cleaning ink carts just as if they were going to be filled with ink but now fill them with a mixture of 10% ink and hot water.
4. You can either buy a new head or get really aggressive and build yourself a pressure cleaning unit.
Since it is against my religion to flush a printhead (see #1, #2, and #4 above) I think I will start with #3. I will flush one of the yellow carts from printer #1 and #2. I know that they are good carts from the nozzle tests I have run. If I use another yellow cart I will be working with an unknown quantity. I think I will flush the yellow cart from printer #1. The yellow cart from printer #2 may actually be bad (i.e. gives good nozzle test, but will clog the ink inlet eventually).
How will I flush the cart? I will soak the cart in warm (80 F) tap water. After the soaking I will flush the cart with warm (80 F) distilled water. After the flushing I will add warm (80 F) distilled water and warm (80 F) yellow ink (mixture of distilled water with 10 % ink) to the flushed cart and place the cart into the printhead.
Question: Is my flushing method O.K.?
Questions:
1. Do I need to install a set (5 carts) of cleaning carts all at one time or can I use the yellow cleaning cart with the other four carts filled with ink only? I know that that deep cleaning will use a lot of ink. Since I have liters of ink deep cleaning is not a big deal though filling the carts a number of times is a pain.
I see no need to use five cleaning carts if only one ink inlet is clogged.
2. How many deep cleanings can I perform and not do harm to the printhead and/or printer?
3. If I just place the cleaning cart in the printhead for a period of time (overnight, 24 hours, a few days, etc.) will this work? I will not be performing any deep cleanings during this period of time. I guess I could do a few deep cleanings and then let the cleaning cart sit in the printer for a period of timetwo days, maybe.
4. I think it is not a good idea to use windex in the cleaning cart. If the mixture of distilled water and ink does not work I will resort to using the windex, but I will end by using the distilled water/ink cleaning cart to flush out the windex.
Note: I will soak the printhead only if the cleaning cart method does not work.
As it stands now I will fill a flushed yellow cart with a mixture of distilled water (temp. 80 F) and yellow ink (10%, 80 F). I will do two or more deep cleanings and let the cleaning cart sit in the printhead for two or more days. IS THIS A GOOD PLAN? PLEASE ADVISE!!!!!
I will appreciate any help that you can give me. I will not be able to get back to this site with the results of my cleaning until sometime next week.
Thank you.
1. This is the original nozzle test. As you can see there is no yellow.
2. This is the nozzle test after one cleaning and two deep cleanings. There is no yellow.
Here are my specs:
Questions:
Thank you.
