I spent the last couple of days going through all of the kind suggestions that I had received from you guys.
There were many so I reckoned I give each of them a good go in turn and see if one or more of them would cause a reaction or change, just as long as this cookie computer doesn’t boot up saying
“to hell you will”.
The Corsair power supply was the first and it was easy to rule out any dip in supply, because it has built in diagnostic monitoring, also I have 60% more power that I need with this new configuration.
The hard disks were up next but I quickly found out to my surprise that they were change only a short way ago by my son and are also working fine.
He is not a fan of the solid state drives, he likes the wagon wheel type from the bigger slower drives and reckon if they work for years in a server then they’ll work for us, he checks them monthly anyway. (10,000 RPM)
We went on to pull the coin battery out and it too showed up very strongly, so no luck there, and the duel Ram sticks was check in both positions giving no loss of data either.
The computer gets a complete clear out of dust every twelve months and we check the operation temperature before and afterwards, we clean the Fans, CPU, RAM, Graphic card and Hard drives, the differences are surprising.(Air compressor)
I way beginning to think @Emulators suggestion might have some merit to it, and things might have been coming in by way of the monthly updates, but no one else has any similar issues, so it too has to be ruled out as pure Paranoia on my part.
It’s definitely an incompatibility problem of the O/S to maintain itself and remember where it stores its own hardware setting, (Maybe a ram issue ?) but yet it can find them on the very next boot-up.
The problem I had with the previous system was when the O/S would disable some of my printers in the middle of the day, (Not at boot-up time) they were connected to the Motherboard by six USB powered Hubs interlinked, so were my external hard drives and scanner and card reader.
Now you might say Ah ha, it’s the USB hubs that are at fault here, but no, the printers were picked at random when turned off (Greyed out and wrong Icons appear), and were connected to separate hubs, but none of the other components were ever effected, the printers would then be reinstall after an hour or so. ( Unaided)
I might leave the internet connected to the computer overnight, after shut-down of course, and then check the browser history in the morning, just to see what it’s interests might be …
@PeterBJ, I use a Flir C2 Thermal camera on my house too, but never taught of using it on the computer, the next time I clean the inside of it I’ll have a go at testing for hot spots..
The corny thing about this is that the computer works perfectly normal at all times..
click to enlarge.
My fly windows are leaking like a sieve..
