MP250 Cartridges
pangit
Can anyone advise the best way to clean MP250 cartidges, there are numerous ways to be found on the internet.
I have refilled 2 different colour cartridges, one has been refilled several times, and the other, though remanufactured, has never been refilled by myself. Both will not print properly. I've run the cleaning routine and the deep cleaning routine several times, and each time the test pattern is printed, it is not complete. Colours are wrong, and there are white streaks. The ink I used, is supposedly "top quality", but I can't advise the "brand" as it's not marked, but the black from the same set works fine.
Help !!!!
Tri cartridges are not the greatest at refilling properly and can work or not so following the instructions exactly is advisable,
you must have put a colour in the wrong position.
Sometime its just better to use cheap refilled compatibles cartridges because there can be more reliable
than filling your own tri OEMs; you need to get a printer that has separate ink cartridges for reliable safer refilling sorry..
