OK Grandad.. I've never had any problems pulling carts to take a peak, but I was only joking anyway..Grandad35 said:Actually, it has the advantage that you don't have to pull a cart to check its ink level. Many of us pull carts to check the ink levels, but I have never been completely happy when doing this, as it has the potential to cause an ink delivery problem if the sponge/filter is partially clogged and the "ink link" is broken by pulling the cart.
It's a clever way to use a physical property that changes when the ink level drops and which can be measured without pulling the cart.
What happens when the fill hole is opened while the exit port isn't sealed? Since I generally get about 1 drop/second from the exit port when I do this, I assume that the ink pickup will be flooded while you refill. At best, this will just make a small mess when the cart is finally pulled. At worst, it could allow ink to leak around the grommet seal. If you took very long to refill, I could see it allowing ink to pass through the print head and to flood the "cleaning sponge". In an extreme case, I suppose that this ink could even cause cross-contamination with other carts.Speedy1 said:How do you feel about re-filling the carts in-situ? I was advised against this by by ink supply company.
jackson said:EDIT:
You can't say I won't put my money where my mouth is.
Using an old print head and holder, I fed ink into a cart with a hole(reservoir side) just big enough for a needle.
The ink poured through the cart outlet and print head like sh*t through a goose.
Scratch that idea.
