I have been filling my Canon i560 cartridges for quite some time and wonder if anyone has an explanation for why some empty cartridges leak after refilling. The leakage occurs at one of two locations (sometimes at both) - at the vent hole at the rear of the cartridge above the foam filled chamber and at the exit port at the bottom.
I use the same technique for filling all cartridges and some fill without incident and others begin leaking sooner or later after filling. I use plastic electrical tape to seal the drilled fill port and the exit port which seems to work fine with some cartridges and not with others.
Any thoughts or suggestions.
Thank
Frank
Thank
Frank
