- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
Redbrickman's link uses something called Minde mirror bought at IKEA.the glass that comes with the printer
Now you know how I feel sometimes with you.his written English was terrible
Good on, Creality!solved
There was a little jumper pin not quite seated on the motherboard and the micro switch plug was barely hanging on too...what was the cause and the solution, Sherlock
I've had similar problems when modifying things on the printer. Eventually I discover one of the connectors has got dislodged. It's particularly confusing if the connector is still connected, but only just, because then I get an intermittent problem.There was a little jumper pin not quite seated on the motherboard and the micro switch plug was barely hanging on too...
I reckon I spoke to soon, the CR-10 is humming away to its hearts content, but the Feckin Mono Mini is now on the blink, the heat bed has all but stopped working, it used to heat every now and then but it has finally pack in altogether.
I contacted Monoprice.com about the problem and got the, SORRY but you didn’t buy it from us, so sling your hook, I am now trying Amazon to see if they’ll play ball.
I have tried to get a motherboard myself online, but because the printer is so new, I’m been told to contact Monoprice support because theses boards are still under warrantee, I get the feeling I’m chasing my tail...
The only good news is I can continue to use the MP mini with PLA because it’s not necessary to have the bed heated while using that type filament...
