Is This Pro 1 Worth spending Money on…
Wisey
canon Pro-1
this is what im reading :
PRO-1 series ICC Profile Ver. 1.0.0m for Art Paper Printing (Mac)
File version: 1.0.0m
Release date: 20 September 2018
(Optional) This file includes a set of ICC profiles supporting other Fine Art Paper. This set is exclusive for the PRO-1 series.
To use these profiles, the firmware version of your printer must be the latest one (v.2.000 or later). Download the Printer Update Utility from the download library and upgrade your printer firmware, when necessary.
DON’T EVER under any circumstances, even under the pain of death, upgrade your firmware, that a fools errant, I’ll say more later…
o my firmware is original and not even printed on the nozzle check, does that mean its best left alone
As with wireless routers, never upgrade firmware unless it is known to fix a problem you are having or has added functionality you must have. In other words, if it ain't broke then don't fix it.
Most of the new canon paper's profiles are on this new firmware
ICC profiles are software that is "installed" on your harddrive in a specific location for Canon's operating software can find them and offer those ICC profiles for your use.
Canon has collated a number of free printer profiles for non-canon papers to use with your Pro-1 and OEM Canon inks. Installation instructions on the page.
https://www.usa.canon.com/internet/portal/us/home/products/groups/3rd-party-papers/
Tip of the hat to Canon for collecting this info and presenting it to customers at the expense of not using Canon's own papers. Don't worry, Canon more than makes up for it in the cost of their inks. ;)
For now, follow The Hat's recommendations on usage and later on when you have your sea legs then get into the weeds.
Wisey
canon Pro-1
I reiterate my respect for you Stratman and the Hat for taking the time to write back, and you do it because you both are on the top of your game, and you both know exactly what your talking about, so a big thank you to you both for that.
I have no doubt i will be back very shortly with more questions for you boffins to sort :bow
You are welcome. There is no one on the forum more knowledgeable on the care and feeding of printers than our fearless Moderator, The Hat. He is our "North Star". And my friend. :hugs
To keep things simple would it be best i just stick to oem inks.... which is what makes this printer so special i believe, im also confused about paper, do i stick with canon paper,
Pick the paper of your choice, I use Lidl photo paer and I've never ever used Canon paper for any of my prints.
The Pro1 can give you the best or the worst printouts if you select the wrong profile type, there are many built-in profiles provided by the print driver so you’ll have a lot to choose from without needing to import more when starting out.
My advice is use you photos as they are, only edit the size and shape to fit your media, and don’t try to alter hue, colour, saturation or brightness till you know what you’re doing, otherwise you can ruin a perfectly good photo for good.
You have many things to look forwards too and lots to think about so adding more for you to digest will only hinder your progress and pleasure, so when you ready there are many good colour experts here to answer any questions.
Try this test photo and see how it turns out, just set to glossy paper and hit print.. What you see is what you should get..
aw-shucks... :love
Wisey
canon Pro-1
Hat @@ just printed that test print im so chuffed with it, im still green with this printer though, the infeed tray is where im not sure im supposed to load the paper yet, there are two infeed places where to load the paper, the one i selected wasnt the one it tried to draw the paper through, need to read the book more, bloody hell this printing is another entity altogether.
Also is it a good idea to do a nozzle check regular ?, i did a nozzle check before doing the test print, and the PBK that was totally blocked yesterday had one band right across it ??. so it had started to dry up over night...
The test print you gave me to do is perfect, no faults whatsoeverm no sign of banding or smudges whatsoever, very happy bunny.
thanks
Andy
Yes do regular nozzle checks every so often, they will keep you up to date on the condition of your print head and will actual save you on ink…
This is the feed tray you will use for nearly all your prints.. 99.5% of them...
P.S. Your prints will improve even more when you get to use OEM inks...
left-side-lay-jpg.9139
Wisey
canon Pro-1
If i get a new paper and the icc profile isn't on my mac what do i do then, Just a thought.
thanks
Andy
PS @Hat there is another feed tray at the very back of the Pro-1 what is that for ??
