ghwellsjr You are the man.
Sure enough I took off the print-head and applied window cleaner (no windex here n the uk) to the input screens and placed the printhead on cleaner soaked tissue. All the other screens showed movement and ink on the tissue except cyan. I had a piece of tubing handy from a car window washer system (just the right size) , placed over the cyan screen, filled the tube with cleaner and gently blew into it. The amount of pressure applied was just less than blowing up a balloon. It was a bit stubborn at first but then after a few refills of cleaner started to move more easily.
Decided to do the same with magenta . Although magenta cartridge doesnt show any problems, the cartridge takes three times as long to empty even though the ink display says its empty. The cleaner moved through the magenta a little more easier than the cyan. However when I tried the tube/cleaner/blow method on the yellow, the cleaner moved really quickly much more than the magenta and cyan. Does this mean that the cyan and maybe magenta are still partially blocked? Or is it because the yellow sits more directly over the nozzles than the other colours?
Ran the nozzle side and the screen side under hot water for a a minute and just waiting for it to dry now. Going to wait till tomorrow afternoon before I refit it.
Is there anything else I should do?
