The standard nozzle check looks normal except that on the top 6C row (dark cyan) the top half is dark cyan but the entire bottom half is light cyan. (Should be all dark.) The second 6C row (Light cyan) is normal. Very uniform colors so clogged jets does not seem to be the problem.
Then the extended nozzle check printout shows 4 cyan grids at the top. The top 2 cyan grids should be dark cyan and the bottom 2, light cyan. The second dark cyan grid is missing its bottom half. That is, the top half of this grid is dark cyan, and the bottom half is blank. Other than that, all the grids are normal.
Any ideas what this points to?
Thanks for your help!
