Over the years I have come across an issue that I could not figure out but something has come to light.
Here it is. I have used printers and then put them away for a period and then brought them back out for reuse again.
When brought back out, sometimes a printer will give some trouble in the nozzle check pattern. The same printer when used regularly does not give trouble.
One time, after servicing a printhead, I reinstalled the cartridges WITHOUT those inlet seals and the printer worked perfectly. I did not notice that the seals were missing until I found them in a little cup I had placed them in. This was on my Pro9000.
This tells me that the printer can work WITHOUT the seal sealing.
Then one day I brought out a printer and noticed that ink had dried up on the outlet felt area.
So this is what I think could be happening to those printers that are put away perfectly fine but when starting again after a period of rest, gives trouble. The rubber seals that the cartridge sits on are actually letting air in and allowing ink to dry in the outlet of the cartridge. This impedes flow of ink into the printer...giving bad nozzle checks or banding. I'm even wondering if by purging, we are actually washing out the outlet filter at the same time and if in fact this might the cause of the flow issue.
On new printers, I can put them away for weeks and months and not have a problem at all. On older printers is where I was hit with occurrences....the older printers had worn or weak seals....that is my theory.
On a regularly used printer, the flow of ink prevents drying to cause issues, so even if the seal is worn, you won't experience problems. However, when it is not used, the dried ink will become concentrated in the outlet sponge AND possibly in the inlet of the printhead. The inlet of the printhead has a very fine porous filter material and clogging can actually occur there as well.
Rodbam, this could be what happened to your old printhead on your Pro9000. I got hit with the same thing a earlier this year.
These are my thoughts anyway and I could be wrong but it is worthy of consideration and could explain issues that some have faced.
