Hi,
It was recommended I post my question here.
Canon's only response it to take it to a service center. I don't believe the printer is worth the cost, but hate to just throw things away
if they can be repaired and used.
Here is the scenario:
I have two i9900 printers. One is mine the other is owned by a photographic associate. Mine works as new.
His printer stopped working awhile (months) ago and had an error message waste tank full
Contrary to the standard response of send it in to a repair facility I was able to locate the information necessary to clear this error and clean the absorption pads.
After cleaning and resetting the waste tank full error the first print came out pretty close with a good gray. I almost buttoned up the printer and returned, but thought I would go ahead and print out an 8X10 of the test image. I had been testing with 4X6. This print was way different with the now continuing deep pink tint in the grays.
It now prints with good detail, light and dark accuracy, good definition between tonal ranges. While individual colors are pretty close, and pure black is good, it can not print gray.
I understand there is only one black and these printers have a limited ability to accurately create gray tones, but my i9900 is able to get close, very slight blue tint, and with tweaking isn't totally horrible. His printer on the other hand has a deep pink tint, that can not be corrected.
I have installed new Canon inks, tried different papers and printer settings, with all the results yielding the same deep pink tint.
I installed the his print head and inks in my i9900 and it prints fine.
The print heads are clean and unclogged, the inks are good, the prints are clean and detailed.
What is left that would cause this completely unacceptable color issue??
Thanks,
Sam
Thanks,
Sam
