- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Bit of an odd quirk to have to deal with here but having sourced one of these HP ProX551 printers I've found that trying to print a booklet from MS Publisher (2013 in this case) has been particularly annoying because it refuses to allow pagination in booklet mode.
Instead it prints off the first sheet for the requisite number of copies, then moves on to the next sheet, etc... so you're faced with manually paginating everything to get your full booklet.
However, I did find a work-around that does the job.
Took a while to figure out what was going on but here's the really bizarre part... Having gone through all of that, I returned to Publisher and tried printing directly again and now the collate option has appeared as soon as I update the copies number.
Very strange... Either way, hope that's of some use to someone... Probably the usual driver mistakes as I found with the earlier HP K5400 drivers at release.
- Save your file as a PDF at the suitable quality for printing
- Select File > Print
- Click "Properties" and choose your standard print settings for a single sided output
- Click "OK"
- Now choose "Booklet" under "Page Sizing & Handling" and set your binding options, etc..
- Set the "Copies" to the appropriate amount and anything more than one copy will immediately result in the "Collate" option appearing.
- Tick the "Collate" option
- Check for any other settings you need to adjust and then hit print
