HP D2560 Problem..
headhair
I have hp d2560 printer.
I have a strange problem
When I issue a print the printer pricks up the paper slowly feeding inside.
In the halfway the paper stops & the Pointing arrow is blinking red.
How to rectify this?
jasiiboss
Dharamsala, India
There could be many reasons for this problems.
1) Check in control panel if the printer ids properly installed and online.
Right click on the printer, go to properties and print test page.
If Test Pg OK than Printer is properly installed.
2) Open cartridge door
Cartridges should come to the centre, remove and clean them with a soft tissue, especially the copper contacts.
Reseat cartridges
This should solve your problem.
Lastly also indicate if you are using original oem cartridges or refilled/compatibles?
headhair
Thanks for your reply jasiiboss
I have checked with all your advice.
No use..
I think there must be some sensor problem.
jasiiboss
Dharamsala, India
I Just Faced A Similar Problem With A Hp 2560 . Opening The Door Inseating The Cartridge(in This Case The Black) Cleaning The Nozzle And The Copper Contacts Putting It Back And Shitting The Lid And Voila The Printer Works Fine. Try It Out Also Try Changing The Carts.
Rgds
jasiiboss
Dharamsala, India
SORRY FOR THE SPELLINGS A STUCK KEYBOARD IS THE CULPRIT
I Just Faced A Similar Problem With A Hp 2560 . Opening The Door Unseating The Cartridge(in This Case The Black) Cleaning The Nozzle And The Copper Contacts Putting It Back And Shutting The Lid And Voila The Printer Works Fine. Try It Out Also Try Changing The Carts.
jasiiboss
Dharamsala, India
Headhair,
For the benefit of the forum Ps inform if you were able to solve your problem. Improves everybody's learning curve,
Rgds,
Jasii
Latest posts
