astrono_me
- May 7, 2012
Hello all.
First post here. Been lurking around for long. There is a wealth of information in the past threads. The problems I am currently facing has been discussed many times in the past. But after having tried the usual solutions such as a deep cleaning using ammonia, I have some specific questions which I have asked below.
Background:
Owned the Canon Pixma Pro9500 since 2008. 95% of my prints have been photographs on archival media from Red River, Ilford and Museo. The remaining 5% have been documents and CD/DVDs. Printer worked great always, except that it has been very ink-hungry. Never tried third-party inks. There have been times when the printer was left idle for long periods of time. But it always gave me good prints after doing a self-clean (and drinking lot of ink in the process).
In May 2012 the Gray and Magenta tanks would print only half, in the nozzle check. Called up Canon and they replaced the head. My understanding from reading past threads is that when the nozzle check prints exactly half the color, the problem is not a clog but an electrical one. Changing the head resolved the problem. The engineer who changed the head, also checked the ink absorbing pads and said they are fine. It didn't hurt me to buy a new head because the printer had served me great for 4 years. And where I live (India), buying a new printer off craiglist is not an option.
Current problem:
When I printed a few images last week, I noticed banding in the upper half of the paper. Ran a nozzle check and noticed that the Photo Magenta color was printing half again. One half was fine, and the other was faint. Again, the problem was exactly midway on the printed block. In spite of this, I was able to print about 20 photos in 13x19" size on matte paper. The printer does not use Photo Magenta on matte paper.
After I ran out of matte paper, I tried a little troubleshooting of my own. I tried deep cleaning. Since that did not work, I removed the head, and cleaned it with ammonia + water. That didn't work either. So I guess I have a failed print head. I am yet to contact Canon for a replacement.
My questions:
- The service manual for the Pro9500 says that faint prints in a nozzle check indicates a problem in any of these components: Ink Tank, Print Head, Purge Unit or Logic Assembly.. I changed the PM cartridge so that leaves me with either a failed print head, logic assembly or purge unit. I understand that when colors don't print well in exact halves, the problem is of electrical nature. Using this symptom for diagnosis, I can suspect either a failed head or logic assembly. The purge unit doesn't seem to have any electrical function. Can I assume that the logic assembly is fine, because I have never had any other problem (like a misprint).
- Can a failing purge unit kill a new print head? I understand that the purge unit is where the print head rests. So if the purge unit is not doing its job, maybe the print head dies a premature death.
- I find it unusual that the print head would die within 1 year. My usage over the past year has been normal. Is there a bigger problem leading to failed heads? Power fluctuations, maybe? I tend to leave the printer on (with the blue light) for several days on end.
- If the problem turns out to be a failed purge unit or logic assembly, will I still need to replace the print head?
- How much would it cost to replace the logic assembly?
Needless to say, at this point in time I am worried about the amount of money I am spending on this printer. Photography is just a hobby of mine. I'm hoping to find an inexpensive fix to this problem, so I can sell the printer.
Thanks in advance for your help.
Background:
Current problem:
My questions:
