aguywithaquestion
- Nov 10, 2009
I have a Lexmark Z1420 and in the past have bought cartridges from ink2u.co.uk, namely, this cartridge: http://www.ink2u.co.uk/ink-cartridg...4-high-capacity-black-ink-cartridge-1497.html
It's the #34.
Anyway, I am going to be doing a lot more printing than usual, so decided that since you can get a 100ml bottle of black ink for 2.99, instead of one cartridge for 13, it would be a lot, lot cheaper to refill it myself.
This is the bottle I was going to get: http://www.phoenixdirectukshop.co.uk/acatalog/For_Lexmark_Compatible_Ink.php ... it's the top one, for 2.99. So question (1) will this ink work? I'm almost 100% sure it will.
Anyway, as far as I can tell, the cartridge I bought from ink2u (see above) already has a hole in it where ink was injected. So, presumably, all I need to do is put some ink in a syringe, get a needle, push it to the bottom and start squeezing. But my question (2) is... I know there are different widths of needles, so what width do I need and what syringe would this be compatible with?
This is a 20ml syringe: http://www.firstaidwarehouse.co.uk/xpp-sterile_single_use_hypodermic_syringe_20ml_single.html
This is a needle: http://www.firstaidwarehouse.co.uk/...ged_21g_0_8_x_20mm_30cm_green.html#opt_review
How are these?
It's the #34.
How are these?
