- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
I tried out the Pixma Pro 1 over the past couple of day with a few test photos.
Now I am not big into photos at all so I dont really have the right paper to get the best out of this printer, I just use Lidl cheap Sihl glossy photo paper, and I also use HP rolls, gloss and satin papers for A3 + prints.
I put it against 3 other printers two dye and one pigment also itself a pigment.
I can say that if I was buying the Pro 1 to get a very big improvement in quality colour photos (Bering in mind the paper I use) to the other printers that I have, then I would have being very disappointed.
The colour output is just a bit better than my other pigment printer but nothing to shout about its only when I switched to B&W photos that the Pro 1 showed off its qualities, nothing came near to it.
The Pro 1 is faster than the 9500 and only slightly dearer but has the same characteristics of the 9500 in that is it difficult to trick into printing onto the size and the paper type you want (If not standard).
The paper feed is centred just like the iP4700 (which makes it difficult to get exact positioning when overprinting) and can only handle sizes to 420 mm (16 ) in width unlike it's sister the 9500, it also seems to be set-up just for everyday pre-cut out of the box standard sizes preferred.
It has a huge footprint, weights in at 31 Kg (70 lb.), has build-in Canon CISS Unit and is extremely quiet while running; it also has to be turned on manually with the on/off button but can respond to a set time off like the 9500 when idle.
The Pro 1 is outstanding when handling text and graphics which is the main reason why I bought it for and gets top marks for that from me, but for the hobbyist I would still recommend the 9500 as a better option for now.
Simply because the 9500 is more versatile, handles everything that is thrown at it with style and room to spare but above all refilling couldnt be easier so the running cost can be kept well within most guys comfort zone, also the price is dropping with all the rebates on offer at this present time in the US.
To summarise if I were a professional photographer then the Pro 1 would definitely be my first choice printer because it will print his pictures the way he feels that they should be printed and displayed.
Given a bit more time a reliable refill method will emerge which will make this printer much more accessible and affordable to everybody that which can only be welcomed, to be continued..
E&OE.
E&OE.
