- Nov 3, 2004
- Location
- Bay Area CA
- CR-10, i560 ,MFC-7440N
I started having a weird problem with my prints. It was like enough filament wasn't being extruded and/or layers weren't adhering properly. Here's a sample print:
I've tried different files and different settings. I figured something's either wrong with the filament or the printer.
Suggestions were:
Well, after swapping out the filament (Zyltech white PLA) for another brand, the problem went away.
I'm not sure if I got a bad roll or if it somehow "went bad".
So, the good news is that it isn't a printer, head, etc. problem. The bad news is that I have an almost completely full roll of Zyltech filament that I guess I have to trash
Even worse... I have like 10 other rolls from the same order, so I'm hoping I just left this one exposed to the elements too long and the other rolls are fine.
Suggestions were:
- Make sure filament diameter was set properly (it is 1.75)
- Check for nozzle clog (did cold pull / atomic pull and all seemed fine)
- Swap out / test a different filament.
