benzinerwin
- Mar 19, 2009
I've had a couple of defective printers (i865, ip4000, mp750, mp760, mp780) that were basically ok but with bad print heads - which were either clogged or completely burnt to death.
One of the heads did only print colors but no pigmented black on one of the printers.
I found out that this particular print head is responsible for the death of some previously electrically healthy printers: they all were immediately killed after I inserted this head. They all do not print any colors any more. I've tried other, healthy print heads - nothing. Replacing the main pcb did always do the trick and made the printers work again.
So this printer head from hell really killed the printer main PCBs. The signal lines from the print head pass a fuse and then go directly to the MPU. The fuses are all ok. Maybe it's some of the transistors - I don't know, I've replaced some of them just to see if anything changes but with no luck.
Any pointers appreciated...
