Epson Rx500 one head (cyan) misalligned !
vluzhko
Hi All
I use my printer with CIS system .Everything was OK untill after moving my existing CIS start leaking. It was actually leaking outside of the printer so I put it into plastic bag.
Finally it ended with no INK in CIS and I printed out all black ink from cartrige.
I ordered new CIS. Installed. Everything is perfect except 1 head. CYAN is misaligned. Basically CYAN was not the ink which finished. So I did not expect it to clog.
Here is scanned nozzle-check image. Look closer at vertical distorting points on CYAN. How come it could be?
I soaked head in Windex already - no effect at all. made many head-cleans - does not help.
I would appreciate any help. I do not throw the printer out just because of one head problem.
thanks.
Smile
Europe EU
soak the head for 48 hours in clean distilled water and if that does not help it could be perhaps an electrical problem.
vluzhko
Thanks for fast reply
how do I do that?
Is this the same as I did with Windex? I soaked piece of cloth (synthetic cloth for cleaning glasses) and put it into XX tray. then mover head above (it presses XX to the head). I did it only for 3 hours. looks like it did not help much.
Epson does not allow to remove the head easily. + I have my CIS connected.
thanks
Smile
Europe EU
If you can't remove the head then it will be very hard.
Try to use warm water. Don't know how long the cloth will stay warm but it will clean better.
I think you don't need to disassemble the printer but you may need to eventually :(
