18%grey
- Aug 15, 2012
- Location
- SE Kent, UK
- Epson Stylus Pro 3800/9800
I have a problem that only effects the Light Magenta on my Epson 3800 printer.
On doing a 'nozzle check' print out, the density of the 'Light Magenta' ink is semi faint. I can only get a strong flow of normal colour after a 'Power Clean' in the printer menu.
A normal 'Head Clean' from within the Epson printer driver software will not achieve the desired flow of ink.
I use the latest version refillable carts supplied by InkJetFly and use Image Specialists ink. I have just replaced the LM cart with a new one but this did not cure the problem.
Can any one help with this or shed some light on what the problem may be.
