Double print
Paul P Bennett
MG6360
I have a canon MG6360 printer and am using refillable cartridges. Lately all my printing is 3 lines of double print then 2 lines of good print and continues in that fashion for the full document. I have done all the head cleaning and alignment drills but to no avail. Would it be worth it to send in for a service or simply buy another printer?
The printer uses bi-directional printing, so the print head has nozzle sets for both directions of print head travel. It looks to me like one nozzle set for pigment black is dirty/partially clogged. Could you upload a scan of a nozzle check?
Paul P Bennett
MG6360
Thanks Peter for your quick response. Have attached a print test. Not a very good image but it shows the black where the problem is.
Paul P Bennett
MG6360
Thanks The Hat, I'll use the workaround until I can get it serviced as I don't know how to get to the timing strip.
Again, the quick response is great.
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
The nozzle check of the PGBK nozzles appears to be from nozzle erosion (wear). I assume you have used this printer for a lot of text printing? The matrix of this nozzle check is typically printed in one pass (not bidirectionally).
Paul P Bennett
MG6360
Yes, have done a lot of printing. A replacement is only $179 so it's cheaper to buy new than service.
