I think I may have destroyed the print head (CN643A) of my HP B109a, and could do with some advice if anyone would be kind enough to offer any.
I'm using those empty 364 refillable cartridges and non OEM ink, which are HP compatible. Although the printer was working fine, I wanted to give the print head a good clean on the underside and get rid of the dried ink from the sides which had accumulated over time. Yes, in hindsight, I should've stayed away from those shiny gold jets, but I took a cotton swab to it and removed the wet ink, and after I reinstalled the print head, it started giving out lines. Since then, I run the cleaning maintenance several times, but cyan refused to give out any colour, although MYK worked fine streak-free. I have soaked the head into water for quite a few hours and made sure that no more ink was running from it, and even used Isopropyl alcolhol (IPA) giving it a good overnight soak (YouTube instructions), but everything I've tried, just doesn't work - cyan is still not working. Running a second-level maintenance clean shows a little cyan streak-free square, but then it just stops working again when printing!
Anyway, if any of the above wasn't stupid enough, what I did next probably is. I got really frustrated, and got a safety pin with a fine head and scored it gently across the cyan jet and possible others (I cannot for the life of me remember), thinking that maybe some of the cotton from the swab attempt may have got lodged inside the jet. The print head does not work now! The black streaks and produces blots on the paper, the magenta and yellow still work fine, sometimes with streaks, and the cyan is still dead. A new CN643A costs 33 inc vat and delivery, so perhaps I should just but another one? Is my old print head destroyed or can it still be salvaged somehow?
Thanks for listening, and I promise not to be so abusive to my print heads in the future
